Neutral Safety Switch
Old Sep 16, 2009 | 05:32 PM
gilllawn's Avatar
gilllawn
I have an 86 Ford F350 Dually with the 7.5 auto
I have to move the shift lever around before the starter will engage so I know it's a problem with the neutral safety switch. What I don't know is if the switch is in the column or on the tranny. C6 btw. So, does anyone have a good schematic or diagram that will show me EXACTLY where this switch is? The manual I have is vary vague and does not have any diagrams.
Old Sep 16, 2009 | 07:24 PM
ctubutis's Avatar
ctubutis
It's on the C6, prolly 4 wires in a dual-purpose switch; two for the backup-lamps switch,
two for the NSS. I don't remember the exact colors as to what is what but you might be
able to figure it out if you crawl under there and look....
Old Sep 16, 2009 | 07:50 PM
bghnkinf250's Avatar
bghnkinf250
It sounds like they are out of alignment. You need a certain size drill bit (#43 I think?) and you put it into the hole in the side of the switch body. You have to align 2 or 3 plates in the switch with it.
Old Sep 26, 2009 | 09:44 AM
Brooksd1991's Avatar
Brooksd1991
Look where your shifter is on your transmission and 2 bolts hold it in. 3/8s? A few clips hold it to the frame and a plug in. Just a few simple pieces and very easy to change.
Old Sep 26, 2009 | 09:54 AM
gilllawn's Avatar
gilllawn
Got it everyone. Thanks
80s Trucker
Electrical Systems/Wiring
Aug 21, 2014 07:29 AM
66F250CS
Apr 5, 2014 01:43 PM
Truxx1956
Aug 22, 2008 03:31 PM
Gregory Glaser
Jun 8, 2007 02:54 PM
rick
Feb 23, 2000 10:43 PM
