so is there a way to test without pulling head off first?.. on cylinder 6 i pulled the rockers and i can shake around the upper valve spring.. i shouldnt be able to do that right? just to refresh myself the bigger valve is the exhaust valve right?
What do you mean by upper valve spring? You can move the valve spring retainer?! Nope, shouldn't be able too. You may have some serious damage. Bite the bullet and pull the head. Sounds like you have a broken valve. Way more than you bargained for.
The intake valve is the bigger one on 400's. The valves are fairly closely alligned with the ports.
The valve order on left side heads on 400's is E I E I E I E I, starting from the front.
i would mean the intake on the 6th cylinder then by the upper one lol.. and i mean i can like shake the spring itself.. like there is play.. im gonna pull the head.. just gotta wait on the funds to get a new gasket and gonna probaly go through the other head b4 i put it on.. Thanks all i will update when i get the head off..
Ok Thanks for all your help guys.. the exhaust valves lost their seats and were sucked in.. and they were cracked like hell.. so deffintaly the problem.... ill post pics of the head soon just got find out how to upload him from phone.. :P.... but i need some more help.. just did the swap yesterday it worked fired up and drove it around for a few hours.. ran great no problems at all.. got home parked it and went out this morning to start it and no go... acts like no spark.. checked timing and different coil. my thoughts are something in the dist or the computer.. but would it just got bad like that?.. without warning..? thanks again
ok so its not good if i screw in the idle mixture screws all the way.. and it still runs.. actually i think runs better then with them screwed out?.. lol
