79 400m runing right issues
Old Sep 16, 2009 | 02:48 PM
maskedman's Avatar
maskedman
Hhttp://www.users.bigpond.com/ergoff/vac1.htm.This is a place to look at vacuum gauge interpretations.
Old Sep 16, 2009 | 02:54 PM
northerndave's Avatar
northerndave
have you rebuilt the carb? it isn't just an accelrator pump diaphram gone bad is it?
with the motor not running if you look down the carb throat with a flashlight & pull the throttle back by hand do you see the squirt gun streams of gas from the accelerator pump?
Old Sep 16, 2009 | 03:02 PM
StarTrash's Avatar
StarTrash
no i havnt done a vac test..
and i tried a different carb still same thing.. the carb does smoke for a little bit after i turn off the truck.. like its still got gas down there..
Old Sep 17, 2009 | 09:59 PM
i-w's Avatar
i-w
have you even checked the carb bowl floats are set properly. not stuck open?
Old Sep 17, 2009 | 10:08 PM
StarTrash's Avatar
StarTrash
On a stock carb i wouldnt know how to check.. could you expain or link a way to check?
Old Sep 17, 2009 | 10:10 PM
Colo79Ford's Avatar
Colo79Ford
Have you ever had the distributor completely out of the block?? I had similar problems, and it ended up being thta the distributor roll pin had sheared, and turned the gear on the dizzy shaft a few degrees to where it idled fine but didnt do anything for power. Try another distributor!!
Old Sep 17, 2009 | 11:08 PM
StarTrash's Avatar
StarTrash
nope i havnt had the distr out of the block.. but i will check it out.
Old Sep 18, 2009 | 12:48 AM
460/5's Avatar
460/5
Zombie Survivalist
i just got done reading a deal about 400Ms. they came from the factory with emissions in mind and made like 175 hp. this was because they came from the factory with the cam retarded 6 degrees. the one they did a rebuild on made 65 hp on the dyno. they did a rebuild for less than $2000 and made 385 hp and 475 ftlbs of torque. naturally i cant find the article now, but it also said that the cam had like 6 flat lobes when they first took it apart for the build.
Old Sep 18, 2009 | 09:07 AM
StarTrash's Avatar
StarTrash
ok well i tried a few things today.. i just messed with the carb a little sprayed wd40 around the intake seals and no change in idle or anything havnt messed with the fuel pump yet.. i just reved it all the way and let it roar for about 3-6 seconds and it sounded good to me.. just some smoke came out the pipe.. now in drive it still idles rough but when drive it down the road seems to have a little more power... im stumped?..
Old Sep 18, 2009 | 12:28 PM
460/5's Avatar
460/5
Zombie Survivalist
get on the highway in a low gear and let that puppy scream. just drive it that way for 10 min or so. get the carbon blown out. stop at napa and get some sea foam and add that. sounds to me like youve just got carbon buildup issues. use the "add to intake" directions. the tons of white smoke it will make is NORMAL. do it outside.
Old Sep 18, 2009 | 12:38 PM
StarTrash's Avatar
StarTrash
lol i wont quite do the highway but ill do a country road :P.. but ill try it..
Old Sep 18, 2009 | 12:45 PM
montana_highboy's Avatar
montana_highboy
Originally Posted by StarTrash
when i press the gas it just dont feel like it accerlates very well... like stumbles.. never smoothes out.. almost no power..
Is your vacuum advance working? do you have it connected to ported or manifold vacuum?
Old Sep 18, 2009 | 03:23 PM
  #28
StarTrash's Avatar
StarTrash
yes vaccuum advance is working.. its connected to a port on the carb
Old Sep 18, 2009 | 04:15 PM
  #29
montana_highboy
Which port? above or below the throttle blades? above the blades pulls ported vacuum and below the blades pulls manifold vacuum, if you're connected to the latter then you're pulling in all your vacuum advance at idle which would create an off idle stumble and lack of acceleration like you've described.
Old Sep 18, 2009 | 08:45 PM
  #30
StarTrash's Avatar
StarTrash
its connected to the carb in the front its really low on the carb.. it idles great.. but in drive idle crappy and doesnt really want to accerlate.. im gonna run it in low gear down the road tomorrow see if that helps but it does a little better off the start now but after about 1/8 of the throttle there is basically no power ..
