Sponsored by: Real Truck
Upgrading tires
Old Sep 16, 2009 | 11:48 AM
jollybear's Avatar
jollybear
Upgrading tires
Hi there,
I have a 2008 F250 with 275/70/18`s on it......Procomp has a deal on tires right now and was wondering what size I can move up to without getting into a transmission programer......would a 33x13.50 18 work???
Thanks for the help
Old Sep 16, 2009 | 11:50 AM
jollybear's Avatar
jollybear
Upgrading tires
Hi there,
Thanks for the help <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
Old Sep 16, 2009 | 11:55 AM
R-T0r21on's Avatar
R-T0r21on
Yup. Stock tires you mention are roughly 33" dia. They're a lot wider & heavier though, so be prepared to lose MPG's.
Old Sep 16, 2009 | 12:27 PM
brian42's Avatar
brian42
Veteran: Navy
It would depend on how wide your wheel is, but as far as heigh is concerned it shouldn't be a problem (the new tires would be about 1/10th of an inch shorter, since your 275s are about 33.15" tall).
Old Sep 16, 2009 | 12:31 PM
PERFORMANCE RED's Avatar
PERFORMANCE RED
You can put up to 35"x12.50 tires on your tuck and they will clear just find any Ford dealer can reprogram your speedo for you. I had mine done for 20 bucks and it took less then 15 minutes.
To be safe I wouldn't go any wider then 12.50" tire without a lift.
Old Sep 16, 2009 | 02:37 PM
jollybear's Avatar
jollybear
Great....thanks for your help
Old Sep 16, 2009 | 02:41 PM
jollybear's Avatar
jollybear
So a 35" x 12.5 should fit on the factory 18x8 rim.....thanks for your help....you wouldn`t have a picture of your truck so I can see what they look like would you?
Old Sep 17, 2009 | 07:44 AM
PERFORMANCE RED
Take a look here.
https://www.ford-trucks.com/forums/8...ts-on-18s.html
Adventure Rider
Feb 1, 2013 01:03 PM
moedaddy
2009 - 2014 F150
Dec 6, 2012 07:18 PM
kidoo
Apr 2, 2011 08:29 PM
TheKid1
Nov 27, 2010 06:24 PM
dshupp
2004 - 2008 F150
Sep 24, 2004 03:30 AM
