35x11.5 Toyo Open Country M/Ts On 18s
Also I don't think the 315/75's will fit an 8" rim. The guys at Les Shwab had me put 10" width rims on mine.
Yeah, I wasn't exactly sure if he was talking stock or not so thought I would throw it out just in case.
Also, for what it's worth, a user on another forum .org put 37's on his stock height '08 KR. Not sure if the '08's have more clearance in the wells then the older style. I don't recall him having rubbing issues though. I'll have to go look it up again and see.
The '08s do have more clearance. I'm really just concerned about how skinny the tire would look on a lifted or leveled truck. Toyo has them listed as 285/75/18 on their website.
http://toyotires.com/tire/pattern/open-country-mt
On a stock height vehicle, they probably wouldn't look to bad, still bigger then the majority of the stock tires. It's possible they may look a little thin on a lifted truck, but maybe not, there only an inch thinner then mine and mine look pretty big. As long as you don't go to extreme, they would probably look ok on a moderately lifted truck.
Not too skinny!
Nice looking SD RED! So...if you don't mind...how do you like those Pro Comp A/T Extreme's???
Also...The reason the 35" tire will fit all '05-new is because FORD went to the coil front suspension. From '99-'04 the SD came with leaf springs up front. IMO...check the manufacturer for proper wheel (rim) width recommendations. The 11.5" tire on the OEM rims will look just fine...with a lift or without...IMHO.
biz
biz
