Symptoms!!!!!!!
Old Sep 17, 2009 | 10:24 AM
Brown Falcon's Avatar
Brown Falcon
Originally Posted by bodabdan
What's the correct max/min on the fuel pressure at that point?
45 min, 80 max
Probably won't see anything close to 80 without a shim.
Old Sep 20, 2009 | 10:56 AM
TPM's Avatar
TPM
Kupiec20
Are you sure the fuel cap is not leaking? Any resolution on this one. I'm really curious.
Old Sep 20, 2009 | 05:39 PM
kupiec20's Avatar
kupiec20
i changed the filter and cleaned the screen-i thought i solved the problem, no problems for about 2 days, and sure enough it started to act up again!
Old Sep 20, 2009 | 05:46 PM
kupiec20's Avatar
kupiec20
i'll give you another hint-its only done it twice and both times when i put it in drive it like jumed from first to second gear. not much but enough to feel it. again the CEL light would come on for a few min then shut off. during those few min. it would idle funny!
Old Sep 20, 2009 | 07:31 PM
kupiec20's Avatar
kupiec20
what makes you think its leaking?
Old Sep 20, 2009 | 10:25 PM
TPM's Avatar
TPM
Leaking?
If the fuel cap is leaking it will surge a bit as it leaks off pressure. I had a slight tweak in the filter cap O ring and it did not show a leak at idle. I kept seeing a wet spot of fuel on the left valve cover. The little leak was squirting now and then, kinda like little pee stream, just pissing on out and then stop.
Old Sep 20, 2009 | 10:51 PM
kupiec20's Avatar
kupiec20
would that make the CEL come on?
Old Sep 21, 2009 | 12:25 AM
444dieselrod's Avatar
444dieselrod
Double post
Old Sep 21, 2009 | 12:26 AM
444dieselrod
No
the engine has NO WAY of knowing if it has fuel pressure or not, even with no fuel pressure they will run, but surge badly and stall when you lift the throttle.
you have another issue. please refresh me on the symptoms again, I didnt read all three pages again.
Diesel Rod
Old Sep 23, 2009 | 06:55 PM
kupiec20's Avatar
kupiec20
still having the same issue,for the first time it stalled today when i put it in drive but no CEL light came on.
Old Sep 26, 2009 | 06:15 PM
444dieselrod
have you looked at the shift indicator thing on the trans, the technical term evades me right now. on the side of the trans where the shift lickage hooks up, it lets the truck start if its in N or P.
Diesel Rod
acarter92
Oct 8, 2013 04:39 PM
SLMDLM
May 2, 2010 11:50 AM
silver01
Dec 22, 2004 10:51 AM
Wrecker
Jul 12, 2004 12:36 AM
stillhuntin
May 30, 2004 10:14 PM
