Another Oil gauge?
Old Sep 15, 2009 | 11:12 PM
444dieselrod's Avatar
444dieselrod
Another Oil gauge?
I got my 2.9 shoehorned in tonite, everything is hooked up except the over heat sender wire on the front left side of motor, and the oil level wire on the pan.
with the key on and engine OFF the oil gauge reads in the middle. with the engine running the oil gauge reads 0. ran it for a few miles and no problems so obviously it has oil pressure. Oil is brand new, just poured it in. does that oil level wire need to be hooked up for the oil gauge to work right?
Diesel Rod
Old Sep 16, 2009 | 12:17 AM
g_k50's Avatar
g_k50
yes.........
Old Sep 16, 2009 | 12:26 AM
444dieselrod
sweet, guess I will be trying to connect wires in there tomorrow.. they dont make that one disconnectable, so it got cut.
Diesel Rod
Old Sep 16, 2009 | 10:54 PM
444dieselrod
well I reconected the oil level wire and the gauge still does the same thing so any new ideas?
also the Brake light on the dash and the ABS light are on, what causes that? the speedo works fine all the way to 70, took it for a spin today.
Diesel Rod
Old Sep 16, 2009 | 10:59 PM
g_k50's Avatar
g_k50
is your brake fluid low?
Old Sep 17, 2009 | 12:31 AM
444dieselrod
it was, not anymore. but the problem still exists.
Piolet
May 21, 2012 09:58 PM
antiqueynot
Jan 21, 2012 05:57 PM
78fordf150ranger
May 13, 2011 09:41 PM
johnsf
Sep 2, 2009 07:58 AM
Dog_Brains
Jun 28, 2001 11:37 PM
