Gauge hook up ?'s
Old Sep 1, 2009 | 09:07 AM
johnsf's Avatar
johnsf
Gauge hook up ?'s
I'm thinking of putting a set of gauges under my hood to help with tuning the engine and also being able to monitor changes I make almost instantly. My question is can I just run new wires to the existing sending units and will it effect the readings. I have to add electrical gauges for volts,oil pressure,tach and water temp.I"m also have a vacuum gauge but I will have to hook up that tubing to the manifold.
Any thought's
John F.
Old Sep 1, 2009 | 11:27 AM
C-Leigh Racing's Avatar
C-Leigh Racing
Well, it would save some time from not having to walk around & look at the dash & I guess if everything is hooked up right they should read the same, just dont cross no wires & burn up something.
Be interesting to see what the difference in readings will be between the gauges & after each are hooked up.
Take note of the readings before the hook up & after to see is any affect from haveing two gauges hooked together on one sending unit.
Neil
Old Sep 1, 2009 | 03:02 PM
monsterbaby's Avatar
monsterbaby
Actually I don't believe you can do that. Since the electrical gauges work by sending voltage TO the sending unit and the unit grounds it through a resistor that changes as the reading changes. The 2 gauges would then both be sending a signal and counter acting each other.
Not sure I explained that clear, but the short answer is NO you can not do that, you need seperate sending units for each gauge.
Old Sep 1, 2009 | 04:49 PM
Bear 45/70's Avatar
Bear 45/70
Monsterbaby is correct. The second gauge will double the resisitance of the that the system sees at the guage end. Will read all wrong.
Old Sep 2, 2009 | 07:58 AM
C-Leigh Racing
I stand corrected on that, hope hes not hooked them up yet, sorry.
Looks like hes gona have to do some plumbing to put two sending units at each place.
Neil
mattwoodsd
Sep 14, 2016 05:50 PM
AKHunter93
17
Jun 4, 2015 10:18 AM
351M78
Jan 4, 2013 11:30 AM
GB SISSON
23
Jun 8, 2012 07:47 PM
wldcat65
Mar 8, 2006 07:21 AM
