possibly a silly question...
Old Sep 14, 2009 | 08:30 PM
Alcaeus's Avatar
Alcaeus
I just replaced my head gasket and I was thinking to myself after tightening down all the rocker arms... Is there a particular way to tighten down these rockers or can I just go down the line ***** nilly without doing anything like bringing each cylinder to top dead before tightening or something like that...?
Can someone inform me? I'm not exactly a machinist but I really want to get this right.
Thanks!
By the by: its a 1981 300 4.9 Are these rockers self adjusting?
Old Sep 14, 2009 | 09:30 PM
flipklos's Avatar
flipklos
positive stop rockers. go ahead tighten them.
Old Sep 15, 2009 | 09:25 AM
AbandonedBronco's Avatar
AbandonedBronco
On my '81, they were self adjusting. I believe the mechanic recommended 20 ft/lbs ea. It's been great for a couple years now.
Old Sep 15, 2009 | 11:21 AM
Alcaeus's Avatar
Alcaeus
Great! I tightened them down to 23 FP and left the valve cover off to see if any froth came out (IE more damn coolant in the oil) and it started up fine running fast. I let it sit for a bit and hit the accelerator to bring it down to idle. It died immediatly. She had a hard time starting up again and now she revs in waves. Revving and almost dieing in turn
I havent readjusted my carb yet. the last two cylinders I found were not firing (bad plugs) previously which is remarkable because she ran smooth enough to balance a coin on so I am thinking that the extra load has put the carb way out of adjustment and I just need put it right?
Was it just doing that because the valve cover was off and the corresponding hoses not hooked up? It was very late so I just swore and went to bed muttering...
Thanks for the help guys!
Old Sep 15, 2009 | 11:25 AM
AbandonedBronco
The valve cover off wouldn't affect the running, that's just to keep oil from splattering all over the engine bay. However, if you removed hoses to access the valve cover and missed one or two, that definitely could. I remember fighting to get mine running after removing the valve cover and realized I had unplugged the brake booster vacuum line because it was in the way. Massive vacuum leak there. Could be something similar.
Old Sep 15, 2009 | 06:49 PM
muscletruck7379's Avatar
muscletruck7379
AB is right, definetly sounds like a vacuum leak. after checking your hoses and what not check for it using a can of carb cleaner, just spray it around and when the rpm's go up you have found your leak.
Old Sep 16, 2009 | 10:31 AM
Alcaeus's Avatar
Alcaeus
Well I plugged a vacuum port and found a found a vacume hose that has obviously broken off of somewhere but I just can't figure from where
I just plugged that too and the engine runs like a dream! Sounds great runs great and is smooth like butter!
Old Sep 16, 2009 | 07:57 PM
greyghost85's Avatar
greyghost85
good job, my friend
Old Sep 16, 2009 | 08:38 PM
AbandonedBronco
Vacuum leaks are the worst, but it sure feels good when you find them!
Old Oct 5, 2009 | 11:52 AM
Alcaeus's Avatar
Alcaeus
Hell
So I have finally finished the truck. Worked all the kinks out and put everything back together in working order.
I started to change the oil and guess what
MORE F-ing WATER IN THE OIL!
I guess I need to take it to a shop have them vat it and mic it for cracks/warps
Any other ideas guys?
Thanks!
David
Old Oct 5, 2009 | 06:37 PM
dustybumpers's Avatar
dustybumpers
I'd run it a bit more, and change it again, you may have still had some water left in there from when you did the work. just my .02
