DP vs TDP
Old Sep 15, 2009 | 08:34 AM
  #31
white Buffalo's Avatar
white Buffalo
Originally Posted by bfife
Or you could do an FU chip from PowerHungryPerformance and have 18 tunes you can play with any time at no additional cost.
http://dygytalworld.ehost-services13...p_Package.html
Barney
Hey Barney,
How do you like the FU (free upgrades) chip & chip burner from PHP? User friendly?
This is interesting -------
From PHP's Website:
"If you have a stock or mildly modded 7.3L PSD, the F.U. Chip (that's Free Updates!) may be what you've been looking for!
For only $495, you will receive a blank 6-position chip and a chip burner, but that's just the beginning! You will also have unlimited access to EVERY PHP calibration available for your truck (15 - 20 calibrations, depending on your PCM code) -- all the funky calibrations as well as all the standard performance levels -- using our Phoenix Flash™ Software.
The best part? You can update your chip FOR FREE as many times as you'd like. Not only can you try every single file we have... you can also customize your chip as often as you want. Going on a long trip cross country? Great! Download Fuel-Sipper™, Anti-Theft, Stock, 80hp, 100hp, and 120hp off our server. Towing a boat through the mountains? Super! Dump the 100hp and 120hp and reburn the 25hp and 40hp tunes onto your chip. Thought you'd use SmokeShow™ but realize that you haven't touched it in six months? No problem! Reprogram another calibration onto that level.
This product will also be ideal for customers who plan on adding performance injectors, "big-oil" HPOP systems, or other heavy mods sometime down the road. All you have to do is contact us with your modifications, Bill can write your new custom files (currently $30 each), and you'll be able to download them using Phoenix Flash!"
Amazing how more products keep coming out for the 7.3L still.
Old Sep 15, 2009 | 08:36 AM
  #32
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
Originally Posted by aklim
I had the thought that you gave me 2 60HP tow tunes instead of the 40 and 60. The EGT never dropped during towing even when I went to the 40 Tow. Checked and double checked for a boost leak and was about to call you to check it. The Up Pipe on the driver side was sooty and so was the trans on that side. Any chance DP-Tuner will warranty the leak and get me a set of Up-Pipes?
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old Sep 15, 2009 | 08:57 AM
  #33
Orezona's Avatar
Orezona
Originally Posted by white Buffalo
Hey Barney,
From PHP's Website:
I've got my burner software installed and activated. Just waiting on to try it out. I think I will change my 80 performance for 80 tow and Wisper for 80 daily driver this weekend. FOR FREE
Old Sep 15, 2009 | 11:50 AM
  #34
hucka1a's Avatar
hucka1a
Do the "code tunes" actually negate the necessity of a Overboost Annihilator? Or do the code tunes just keep the CEL light from coming on?
This is from the programming help page on DP's site.
preset parameters in the PCM are relaxed so the SES light is not tripped under normal driving conditions.
Old Sep 15, 2009 | 12:18 PM
  #35
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
actually both
__________________
Old Sep 15, 2009 | 01:09 PM
  #36
Groovy Chick's Avatar
Groovy Chick
Former Vendor
Awesome, Jason. Give us a shout and let us know what you think about the other tunes!
(Just boxed up your item and it will ship today -- a freebie for making me smile earlier . Enjoy!)
Old Sep 15, 2009 | 01:49 PM
  #37
rat49f6's Avatar
rat49f6
Do u still have to remove the chip to install new tunes with the php fu chip?
Old Sep 15, 2009 | 01:53 PM
  #38
spdmpo's Avatar
spdmpo
I can tell you on my truck that I still need a OBA. Jody live tuned my truck and did all the tunes as 'no codes' tunes. At the time I had a OBA on. When I got home I took it off, and instantly set a CEL after hitting 25# of boost and it did it several times. So I put it back on and hasn't happened since.
Old Sep 15, 2009 | 02:27 PM
  #39
Orezona's Avatar
Orezona
Yes.
I will be modifying the black plastic box so the chip can be removed with the case still mounted.
Old Sep 17, 2009 | 09:15 AM
  #40
Groovy Chick
Former Vendor
Awesome, Jason! Please take a picture of it and e-mail it to us. I'm curious to see what you do!
We have a couple of projects in the works which would eliminate the need to remove the chip to reprogram it. Just a matter of Bill finding the time to work on it.
Old Sep 17, 2009 | 09:26 AM
  #41
white Buffalo
Thanks Huck,
When I read this on DP's website I was curious as to what constitutes "normal Driving" and under what conditions will the CEL light come on using the "no code tunes" - since alot of us here aren't "normal"......
Old Sep 17, 2009 | 09:46 AM
  #42
Izzy351's Avatar
Izzy351
Here's what mine looks like -- I can pull & re-install the chip easily...
With & without chip:
Old Sep 17, 2009 | 10:04 AM
  #43
Orezona's Avatar
Orezona
Joe,
Are you using anything to hold the chip in? I'm going to use a dremel tool and try for some straight cuts I wish I'd had time to do it last time I had it out. But with PHP coming through for me right before I went on vacation there just wasn't time for it with all the packing and stuff going on.
Old Sep 17, 2009 | 10:06 AM
  #44
aklim's Avatar
aklim
Joe,
I did the same cut on the plastic. I hold it in with duct tape. HOWEVER, I do put sponge between tape and chip
Old Sep 17, 2009 | 10:10 AM
  #45
Orezona's Avatar
Orezona
That is exactly what I was thinking. Cut out a piece the size of the opening to keep the bad stuff out.
