Tachometer wireing
Old Sep 14, 2009 | 12:45 AM
nextalcupfan's Avatar
nextalcupfan
Tachometer wireing
im wanting to put an aftermarket tach (autometer or something) in my 1995 Ford F-150 5.0L/302. my dash doesn't have a tach in it and the engine might be a mustang 302. the ignition module isn't on the distributer dispite the fact that its MAP
any help would be apreciated
Old Sep 14, 2009 | 01:50 AM
JHAM's Avatar
JHAM
I just put a tach in my truck and the green wire goes to the neg wire on your coil, the white is for the light in the tach, i ran it with the power wire to have the light on all the time, then obviously you have the red and black wires for power and ground.
Old Sep 14, 2009 | 01:51 AM
nextalcupfan
which ones the neg on the coil?
Old Sep 14, 2009 | 02:14 AM
JHAM's Avatar
JHAM
you will have to use a test light to see, unplug the coil and see which wire is hot, my truck had a red and a brownish colored wire going into the coil, the brown one was neg on mine, but the wiring may be different on yours
Old Sep 14, 2009 | 03:47 PM
nextalcupfan
thanks for the help
Old Sep 22, 2009 | 02:20 PM
cmcolfax's Avatar
cmcolfax
There is also an article/write-up here on the forum on how to swap in an OEM guage cluster tach...
Something to think about...
-cmc-
Old Sep 22, 2009 | 06:28 PM
Hunt4Fun's Avatar
Hunt4Fun
-cmc-
I just did exactly that. Picked up the instrument cluster at the junkyard for $22. Swapped the parts around and everything works great. Much better than aftermarket which is what is on my 90. The 93 looks a lot better with the factory tach.
Old Sep 22, 2009 | 08:36 PM
cmcolfax's Avatar
cmcolfax
I've got one laying on the work bench waiting for a free afternoon...
Grabbed it out of a 92 Bronco in the junkyard for $13
-cmc-
blifsey
Jan 13, 2025 12:46 AM
quesey
1978 - 1996 Big Bronco
Dec 26, 2013 06:10 PM
82fordowner
Apr 8, 2013 02:54 PM
droppedf100
Feb 23, 2009 10:19 PM
302 F-150
Electrical Systems/Wiring
Jun 13, 2007 02:06 PM
