393-408 with SD?
Old Sep 20, 2009 | 06:31 PM
351slug's Avatar
351slug
393-408 with SD?
Plan on building some kind of stroker within a year or two, Haha. Will the SD setup work with the SD friendly Comp cam and some nice flowing heads? If not, would like to go with bigger cam and carb with stand alone Baumenator for the E4od. Im not going to MAF. Carbs are fine with me. Right now Im just kicking ideas around.
Old Sep 22, 2009 | 09:58 PM
rla2005's Avatar
rla2005
You will be on the outer limits of the stock computer with your stroker. It's not impossible, but with a mild cam and some tuning you could get it work. You will be able to get more aggressive with your cam and tune if you go MAF. Even more is possible with an aftermarket FI controller. All it takes is dollar$$
