fuel pump "disc" leaking
Old Sep 13, 2009 | 02:16 PM
ms1780's Avatar
ms1780
I have a 97 psd with cali emissions. I had to change the fuel pump due to a leak and apparently poked a pin hole in the "disc" on the top of the wishbone pipe the banjo bolt goes thru. I am not sure if the truck even needs this thing since it is not even on regular psd's only the california emission ones. My question is what is it, will it run without it, and how is it removed. If anyone can help please do. It is really heart breaking when you think a job is done and it is just starting.
Thanks,
Mike
Old Sep 13, 2009 | 03:47 PM
pjwoolw's Avatar
pjwoolw
The why is it there who knows. Never heard of anyone running without it in the stock Cali fuel system. It screws on and off. It may have just come loose. The unit and the washer are separate parts.
F6TZ-9N163-AA for the pulse damper.
F6TZ-9160-AA for the gasket.
Y2KFORDPARTS is where I got mine.
Old Sep 13, 2009 | 08:52 PM
Oversize's Avatar
Oversize
Ive heard you can unscrew it and put a plug in its place but nobdoy has actually tried it, that Im aware of.
Old Sep 13, 2009 | 10:32 PM
ms1780's Avatar
ms1780
I pulled the turbo and got the wishbone piece out that the banjo bolt goes thru and removed the pulse dampner. I would like to know if the truck will run fine without it because if it will I will buy a non-cali wishbone piece so that if I ever have to change the fuel pump again it won't be such a PITA. I will have to change the banjo bolt too. If anyone out there has done this please let me know how it turned out.
Mike
Old Jan 7, 2010 | 11:35 AM
darin c's Avatar
darin c
Thought I would try to help close the loop on this topic... I also have a 97 cali with a leaking pulse damper. First off, you can remove the damper (and fuel pump) without removing the turbo on a cali truck. It's a PITA, but can be done. I removed the damper and replaced it with an M14 x 1.5 x 12mm drain plug. (reused the copper washer from the damper) There's no noticeable difference in how the truck runs without the damper.
Old Jan 7, 2010 | 11:42 AM
MADVAN's Avatar
MADVAN
It reduces pressure spikes from the splitshots and mech fuel pump.
It will run without the damper.
Damper helps with inj noise and idle knock.
Bill
Old Jan 7, 2010 | 12:02 PM
Copedawg's Avatar
Copedawg
X2 on what darin c said. I didn't remove the turbo https://www.ford-trucks.com/forums/8...ml#post7627132
Old Jan 7, 2010 | 01:36 PM
250turbo's Avatar
250turbo
you should be find.i split mine in alaska in o2,dealer didn't have part,so used a bolt in it's place.no problem with it or pump.
Old Nov 27, 2016 | 04:01 PM
timmosazz64's Avatar
timmosazz64
How hard is it to change the dampener? Does the turbo have to come off? Special tools?
Old Nov 27, 2016 | 04:35 PM
BBslider001's Avatar
BBslider001
Try starting a new thread rather than posting in one that is 6 years old. You'll get responses that way.
J ballan
Jan 22, 2018 07:27 AM
CelticOne
Jul 18, 2017 01:10 PM
LittleBlue79
Feb 26, 2017 03:41 PM
Minnesota_Duane
Mar 26, 2016 04:21 PM
