I replace my fuel filter once a month now, because that's how quick it goes from a nice clean glass canister with a white filter to a orangish brown filter with bits floating inside the canister. And I have decided it's time for a new fuel tank, maybe even some new line too.
I want to get the Emission tank in case I ever switch over to an electric pump so I can use that for my fuel return line. I have found the part number for the valve in other threads E7DZ-9B593-A (Thank you NumberDummy). But was surprised at the price for it... Cheapest I've found it for is $40 at Genuine Factory OEM Parts & Accessories | TascaParts.com. Has anyone found it somewhere else (not a junkyard) for cheaper? I exclude junkyards because that's an obvious answer.
OR They appear the same in photos as the breather valves that JBG has for $16. Has anyone gotten curious enough to see if one of those breather valves will seat in the emission hole properly? I'm trying to avoid buying unnecessary parts to test it myself.
