Did the power steering fluid change iaw directions from FTE! Happy to tell ya that not only did the pump quiet down but the brake peddle seems stiffer. Now, I couldn't justify the cost of flushing the system with full synthetic ($8 a quart) just to throw 3.5 quarts away, I used synthetic blend. Don't know the ramifications of using a blend, but I like it so far. I hate being poor. Thanks FTE for the instructions.<o></o>
Good deal, glad you posted, I'll be doing this in a couple days. Tring to find specific brands of fluids is like pulling teeth but shooting for the Mobil syn is my intentions, stay tuned...
I used Mobil1 in mine. Worked out great! I got it for $5.50 a quart by buying by the case from O'Reilly's. Bought enough for the trans and the PS pump change. Four cases of 6 quarts each.
