Stuck diff fill plug stuck - how to fill my dry diff?
Old Sep 14, 2009 | 12:42 AM
79f150toy's Avatar
79f150toy
BTW, for non abs application-most axles have a vent tube, so just put a 3/8 hose on the end of the botlle and fill her up...
Old Sep 14, 2009 | 12:45 AM
phoneman91's Avatar
phoneman91
Good point--just have to make sure not to overfill. .
Old Sep 14, 2009 | 03:13 AM
79f150toy's Avatar
79f150toy
Im sure a "slight" overfill wont hurt much...it is vented so it wont increase internal presure and blow out seals....but obviously too much would prolly create too much drag on the r/p...however, the best thing is to know the capacity for your intended axle and fill it accordingly....
Old Sep 14, 2009 | 07:09 AM
jr32560's Avatar
jr32560
and it's better than running it dry too much would be better than none at all~ wouldn't last long like that
Old Sep 14, 2009 | 06:45 PM
Jermafenser's Avatar
Jermafenser
Originally Posted by phoneman91
Yes- on the 8.8 rear differential. The front differentials on F150 4x4s have the plug in the front axle stamped
Ohh. That explains it. I never knew Ford put 8.8 axles in full size pickups...I thought only the Rangers & Explorers.
Did Ford still put in 9"s into the '80s, or the '90s? Did the 8.8 replace the 9"?
Old Sep 14, 2009 | 11:40 PM
79f150toy's Avatar
79f150toy
Im sure someone else will chime in, but yea they offered the 9" until the mid 80s. the 8.8 was a pretty standard half ton axle in both 2wd and 4wd trucks....
Old Sep 15, 2009 | 09:53 AM
Ricache's Avatar
Ricache
Proud to say there are no runs, drips or errors concerning my diff fluid change.
I've read a few POSTS here about letting RTV set. The directions say you don't need to.
I like watching TiVo'd Horsepower TV programs on SPIKE (think there are 4 of them) and they did a thin bead of RTV on both the Diff and the cover then spread with a throw-away glove (I used a baggie).
So - you don't need to let it set and you don't need a gob of RTV.
That old Diff fluid came out like it was 10W or something less. I can't believe Ford recommends changes at 100K miles.
Is it me or does my truck seem to drive (not run) a little smoother now?
Old Sep 15, 2009 | 11:41 AM
phoneman91's Avatar
phoneman91
These trucks just love it when they get new fluid. And yeah-they do seem to drive better afterwards. Just like they do when you wash and wax them.
You did put synthetic fluid back in -right?? Helps with the MPG.
Old Sep 15, 2009 | 01:04 PM
Ricache's Avatar
Ricache
Phoneman91 - put Valvoline Durablend 80/90 in it. Part synth, part regular. Only other type they had was the Mobile1 and was past my price range.
From what I remember from the last diff fluid change I had done by QuickLube in my Durango - I probably saved $75.00 doing it myself. And it as a learning experience and an adventure.
I'll do my '01 4.7L Durango from now on as well. Dodge says every 40K miles.
/Ricache
Old Sep 15, 2009 | 02:08 PM
phoneman91's Avatar
phoneman91
Richache:
How is everything in Wylie ?? I use to live in Abilene and had a job in Sweetwater. 88 mile around trip each day for almost 5 years. Got a lot of tickets going thru Merkel. I miss living in Texas-except for that ticket thing !!
sammie0126
Sep 20, 2021 09:54 PM
djed
30
Jun 1, 2017 10:39 PM
97ExpGuy
35
Jan 1, 2012 01:22 PM
Capriguy
Dec 23, 2011 06:04 PM
pdqford
Jun 11, 2011 08:52 PM
