changing out rag joint
Old Sep 12, 2009 | 06:43 AM
alchemist1's Avatar
alchemist1
Guys,
Is there a post on changing out the rag joint. It doesn't look that complicated, but just need to know which bolts to remove/loosen.
Thanks!
Old Sep 12, 2009 | 11:02 AM
Furyus1's Avatar
Furyus1
The way I did mine was: I dropped the steering column inside the cab by removing the 2 bolts that hold it up to the dash; you should probably disconnect the shift linkage from the steering column under the hood (close to the firewall) - I forgot to do that on mine but got the job done anyway; disconnect the wiring harness from the steering column under the dash; remove the 2 bolts on the rag joint that tighten it down to the 2 shafts; pull the steering column into the cab of the truck to separate things and give you enough room to pull the old rag joint and put the new one in; reinstall in reverse order...
Old Sep 12, 2009 | 06:00 PM
alchemist1's Avatar
alchemist1
Rag Joint and horn ground
All finished. Not too bad of a job at all. Nice tight steering feel now. Only problem is that the Dorman replacement steering coupler makes no provision for the horn ground. How have folks fixed this. I'm guessing just run a ring terminal crimped w/14 gauge wire on one of the two connector bolts, but the other end of the wire is a more difficult choice. Anyone have to rig one of these??
money pit 69
Sep 1, 2010 10:51 AM
mabigredtruck
Jul 3, 2010 11:46 PM
big64
Jul 11, 2009 02:17 PM
standman
Sep 12, 2002 11:13 PM
BB
Apr 12, 2002 06:28 PM
