3 codes thrown no start
Old Sep 11, 2009 | 01:03 AM
orcal3056's Avatar
orcal3056
7.3, 2003 just replaced both batteries due to no start, slow drag while turning over. ran for week ok and then won't start, same problem slow drag while turning over and no start just turns over like batteies are low. pulled code following codes with edge: p1670 ef feedback sig not detected, p0381 glow plug circuit malfunction, p0603 PCM processor keep alive memory (kam) error. what gives? had to jump it to get home ran fine and wouldn't stArt After shut off
Old Sep 11, 2009 | 06:29 AM
12ozd's Avatar
12ozd
Sounds like a starting system problem.
Begin w/ the basics..
Good batteries,tight clean connections,(pos. and neg.both ends of cables)
Starter drag could be a result of low power to starter,or a bad starter.
Old Sep 11, 2009 | 10:08 AM
harleydude03's Avatar
harleydude03
check your alternator, sounds likr the batteries arent getting charged
Old Sep 11, 2009 | 11:22 AM
F350-6's Avatar
F350-6
Welcome to FTE. Set your truck back to stock to rule out any issues with the edge. Then check your fuses with a test light and swap the relays around.
The issue you want to focus on is the P1670. The PCM and IDM are not talking to each other. This is the reason for your no start. If fuses & relays check good, it's time to check wiring.
Old Sep 11, 2009 | 08:20 PM
orcal3056's Avatar
orcal3056
ok, altenator removed and checked. altenator smoked. rebuilt today at local shop $138. will install tonight.
Old Sep 11, 2009 | 09:44 PM
Tenn01PSD350's Avatar
Tenn01PSD350
I was going to say not enough juice to start but the GP system malfunction concerns me. If that is shorted somewhere, you may burn up the new alternator too.
Old Sep 13, 2009 | 01:17 PM
orcal3056's Avatar
orcal3056
Batteries trickle charged and all seems to be ok. truck starts and no codes are present. rebuilt altenator and on the road again. thanks all for your advice.
F150vettehauler
2004 - 2008 F150
Apr 7, 2014 01:40 PM
stwhite11
Nov 24, 2012 04:49 PM
baronske
Apr 7, 2011 09:43 AM
ajorn
Feb 9, 2010 08:20 AM
desertdogs
Apr 9, 2009 08:25 AM
