302 intake ?
Old Sep 10, 2009 | 06:42 PM
jsalty's Avatar
jsalty
302 intake ?
I am replacing my worn out autolite 2100 with a Holley 4160 600cfm. I would like to know what intake manifold would be best to use. I like the Weiand Stealth but unsure if it is the right one to use vs. the edelbrock performer. any suggestions will be appreciated.
The engine is a 1970 302 stock except for headers and an open air filter. Auto trans too.
thank you
Old Sep 10, 2009 | 08:47 PM
david00f150's Avatar
david00f150
Can't go wrong with the edelbrock. Price is cheap and performance is good!
Old Sep 11, 2009 | 11:52 AM
Kemicalburns's Avatar
Kemicalburns
what vehicle is the motor in?
Old Sep 11, 2009 | 02:55 PM
gearhed1971's Avatar
gearhed1971
https://www.ford-trucks.com/forums/a...pictureid=4278 here are the numbers for my setup on a 289 - weaind stealth and 4160. I like it,no problems.
Old Sep 11, 2009 | 03:13 PM
jsalty's Avatar
jsalty
1970 F100 2wd short bed
the engine is a 68' 302 or 289. I have not Idea how to tell them apart without disassembling.
Old Sep 11, 2009 | 03:15 PM
jsalty's Avatar
jsalty
You have noting else done to the engine? just the intake and a 4160?
that is something to look forward to by just adding the 4bbl..
Thank you..
Old Sep 11, 2009 | 03:46 PM
Kemicalburns
weiand intake is a great intake on a truck. also rear gears are a big help if your looking to go fast. do you know what you have out back?
Old Sep 11, 2009 | 04:30 PM
jsalty's Avatar
jsalty
Ford 9" with 3.83 installed and a spare 3rd member in the shed with 4.11's or 4.10's I forget. Need to look at it
Old Sep 12, 2009 | 12:24 AM
jsalty's Avatar
jsalty
What are the advantages and disadvantages of having the 'rear water crossover' vs. Not having it.. (Weiand 8020 vs. Weiand 8124)
what are the advantages and disavantages of having a 'high rise' vs. a 'low rise' manifold ? (8020 vs. 8124)
Thanks all..
Going on a stock + headers & open air filter 1968 302/289 in a 1970 F100.. Original engine as far as the paperwork and id plates go for the truck..
Old Sep 12, 2009 | 09:58 AM
doug1222556's Avatar
doug1222556
The rear crossover has something to do with cold weather drive-ability I think. It supplies some heat to the carb or so I've been told. With or without is not a big issue as far as I know. Edelbrock's don't have them.
The only reason I could see to go with the 8124 is if you had hood clearance issues or just wanted a more stock look. While they don't show a difference in the stats, higher is better as it will give you a teeny bit more velocity and better flow.
FWIW- I have heard that the Weiand's are hands down better than the Edelbrock's, but I can't remember which intakes that were compared. In other words, if they were single planes, then that info means nothing.
Old Sep 12, 2009 | 08:51 PM
jsalty's Avatar
jsalty
Thank you very much for the info. I believe I will stick with my first thought of the Stealth 8020..
Thanks again..
Old Sep 13, 2009 | 06:05 PM
jsalty's Avatar
jsalty
I was just offered a trade -- My freshly rebuilt 600cfm Holley 4160 for a freshly rebuilt 500cfm Holley 2300...
I have a 2bbl intake still on my truck, I was going to spend the $175 for a new 4bbl intake but by doing this trade I could not spend a dime...
Any thoughts on if I am being taken on the trade, is the 2300 worth a crap, show performance suffer?
I am kind of leaning to not making the deal. Let me know your thoughts please..
Old Sep 13, 2009 | 08:01 PM
gearhed1971
Nah,I wouldn't trade.You'd get better mileage w/ the 4v carb,and better power when you need or want it.I have a 500 cfm on my '73 f100,and it's only ok.
Old Sep 13, 2009 | 08:11 PM
jsalty's Avatar
jsalty
That's what I was thinking but I would save a few hundred in parts and a Saturday afternoon by just swapping carbs, I would probably spend it later anyway.. Guess I could put an adapter plate to run a 4v on a 2v intake.. anyone ever use one of these?
thanks again..
Old Sep 13, 2009 | 10:45 PM
85e150's Avatar
85e150
Run the 500 2bbl if you don't want to get a 4bbl manifold. 4bbl on a 2bbl manifold is a waste.
The 500 cfm 2bbl needs to be fiddled with, as the accelerator pumps are often overkill for a smaller engine.
I ran one for a short time on a 289, but then went to a Motorcraft 2bbl off a 390 that worked better and didn't bog the motor when I nailed it. (bog for a second then take off with a puff of black smoke and a chirp from the tires....)
Big_Joe
15
Sep 28, 2009 02:16 PM
Flexfuel-Dave
Engine Swaps
Jun 11, 2005 11:20 AM
ClatonK
Oct 10, 2004 06:33 PM
1yamman350
Oct 24, 2003 08:12 PM
the lloyd wards
Mar 7, 2003 05:50 PM
