Hard shifting
Old Sep 10, 2009 | 06:37 PM
gomfrddy's Avatar
gomfrddy
Hard shifting
95 7.3 dually auto 223k, was coming home from work, bout 1 hr commute, when I got into town the truck started shifting hard, both up and down shifts. I have noticed a small leak coming from the diff which I've been meaning to ge to. could low diff oil cause that? or Am I looking at a tranny problem
Old Sep 10, 2009 | 07:19 PM
Cuda_jim's Avatar
Cuda_jim
Tranny for sure...not the rear diff. Was your OD light in the end of the shifter flashing.
If so, get it scanned for codes...The PCM/TCM raises the pressures in the trans to protect the clutches when it senses slippage or too much heat... making the shifts feel very hard.
Old Sep 10, 2009 | 07:24 PM
gomfrddy's Avatar
gomfrddy
no lights flashing, will get it scanned, thanks so much
Old Sep 17, 2009 | 03:06 PM
gomfrddy's Avatar
gomfrddy
ok, got it scanned, no codes but the mecanic says the tranny is toast wtf?
Old Sep 17, 2009 | 03:10 PM
Brown Falcon's Avatar
Brown Falcon
is the fluid clean? smell burned or anything?
Maybe clean off your VSS that plugs into the rear diff
Old Sep 17, 2009 | 08:25 PM
kupiec20's Avatar
kupiec20
what does VSS stand for?
Old Sep 17, 2009 | 09:52 PM
69 stang's Avatar
69 stang
VSS: Vehicle Speed Sensor. located on top of the rear dif
Old Sep 18, 2009 | 11:15 AM
444dieselrod's Avatar
444dieselrod
the if the ICP gets a bad reading it will also raise line pressures and shift hard.
does the TC lock up? if the tail light plug behind the bumper has a bad connection the TC wont lock up and it confuses the trans doing the same thing.
Diesel Rod
Old Sep 18, 2009 | 12:06 PM
kupiec20's Avatar
kupiec20
so how do we clean the VSS, and if its not dirty is it a good idea to clean anyway?
Old Sep 19, 2009 | 01:44 PM
gomfrddy's Avatar
gomfrddy
OMG! the things you learn here! flushed fluid, fluid dirty but not burnt, no metal in the pan, will try vss and btw my tail light happens to be hangin down from the wires, will try all that, thanks! will keep you posted
Old Sep 20, 2009 | 06:31 PM
gomfrddy's Avatar
gomfrddy
SUCCESS!!!!!!!!!!!!!
Took out the VSS, capped the bumper wires reset the computer, drove the truck, shifted hard a couple of times and then it smoothed out!!!!!!!!! thanks so much to all
trevorcapps
1997 - 2003 F150
Feb 21, 2013 08:04 PM
turnkyle
Oct 11, 2011 09:59 AM
Jim Hunt
17
Jun 27, 2010 06:41 AM
mtmatzf150xlt
Oct 8, 2009 08:12 AM
