Shouldn't be an issue as long as its toward the end of your exhaust (after muffler)..
I have mine plumbed into the fresh air vent that goes into the cab.
Otto -- that has been tested with pressure/vacuum gauges on the engine, and the pressure goes *UP* in the engine when the CCV is plumbed into the exhaust, no matter how or where it was done (yes, even at the end of the tail pipe).
I would strongly suggest you avoid doing it. Mine is run all the way out by the tail pipe through a hose, and so far, no issues. It was the first mod I ever did back in Feb/March of '07 -- shortly before I met you down in PC. It's still there and still working...
You could vent it through the exhaust as long as it was introduced via a venturi. Very simple, just some mild metal work for the exhaust pipe. Then the flow of exhaust, through the venturi (pressure gradient), would create a vacuum for the CCV.
I think you may have a problem at idle or low speed, not enough exhaust flow to creatate the pressure gradient needed to make the needed vacuum. just my .02 cents
Thanks bfife. The collection unit can be ordered from McMaster-Carr online. Here is a link to it: McMaster-Carr
It is the Nylon T-strainer with clear bowl. I use the 1.5 inch opening port unit. I ordered it with the 40x20 mesh screen which is a larger opening mesh screen. I believe the percentage of open area is between 40 and 50%. The screen is just a clinging surface for oil in the vapor stream. The lower the number screen selection, the larger the mesh opening. A couple other forum members wanted me to do a complete parts list with fittings, reducer connections and barbs. The entire set up. I said I will get that done. I will be doing that some time in the next week.
Company: Industrial Specialties Mfg. Industrial Specialties Mfg.
Item: Nylon 1.5 inch male to 1 inch female reducer (quantity 2)
Part #: NC-24-16 (Price $1.87 each)
Item: Nylon 1”x 1” male barb 90 degree one end threaded elbow (quantity 1)
Part #: N16MEB-16 (Price $1.26)
Item: Nylon “1 x 1” male barb 90 degree elbow (quantity 1)
Part #: N16EUB-16 (Price $1.44)
Home Depot items
1” inside diameter straight brass barb, only need 1. (connects return hose to L shaped intake short rubber hose)
1” copper 90 degree copper fittings, only need 2. (one to connect reversed dog house to hose and one for return path route to connect to intake.)
Hose specs -
Approx 13 feet of 1” inside diameter rubber hose if mounting unit in the frame rail location I used. I used Gates Premo flex petroleum rated hose but Parker petroleum rated hose is good stuff as well. Don't use common heater hose.
