Pushrod Help.....
Old Sep 9, 2009 | 11:23 PM
maldonadom10's Avatar
maldonadom10
Pushrod Help.....
Pushrods were installed out of order........How can this be corrected....Anyone have a picture of a intake manifold with the carb. installed to use as a guide for vacuum hoses and springs from carb. 1978 F150 Custom 351M....
Old Sep 10, 2009 | 07:09 AM
mark a.'s Avatar
mark a.
It doesn't matter what order they go in.
Old Sep 10, 2009 | 07:44 AM
maldonadom10
Thats what I thought, but a friend had told me that if they were out of order the piston would hit them and would make them pop, and bend the rod....is that not true.....all the pushrod are the same length so I thought it should not matter.....
Old Sep 10, 2009 | 10:17 AM
Ronzi's Avatar
Ronzi
Your friend is wrong. The piston can not hit the push rods. Ideally youd want to put the push rods in the same place because they have "worn in" so to speak in that location. The same with the rocker arms and lifters but its not going to destroy anything if they dont end up in the same spot.
atccracing
Mar 13, 2011 05:56 PM
thepieceworker
Aug 23, 2004 09:31 PM
macguyver
Jan 6, 2003 11:18 AM
drahn
Feb 26, 2002 12:08 AM
omnipotant1
May 19, 2000 11:32 AM
