Sponsored by: Auxito
trasfer case leaking
Old Sep 9, 2009 | 09:52 PM
dude73's Avatar
dude73
hello all i have a 97 f150 4x4 with a 4.6 auto with 257000 miles my transfer case started leaking at the tailshaft how hard is it to get the tail off the transfer case
Old Sep 10, 2009 | 08:13 AM
dude73's Avatar
dude73
nothing on this
Old Sep 10, 2009 | 10:19 AM
alberta46's Avatar
alberta46
take off the driveshaft. 12 mm 8 point socket. then take off the big nut. slide out old seal and replace. Note there will be some leakage when you remove the seal. Make sure you mark the drive shat so its put back the same way.
Old Sep 10, 2009 | 08:21 PM
dude73's Avatar
dude73
will the tail unbolt from the transfer case
Old Sep 11, 2009 | 10:13 AM
dude73's Avatar
dude73
thanks but i help with the transfer case not the rearend
Old Sep 14, 2009 | 10:25 PM
fordmerc's Avatar
fordmerc
If it is the seal between the t-case and the tail shaft, you will need to take the driveshaft out, remove the speedo sensor and unbolt. If it is the rubber lip seal at the end of the tail shaft, just remove the driveshaft and use a screwdriver to pop the old seal out. Then, lightly tap in a new seal.
Old Sep 14, 2009 | 11:36 PM
papajoemrt's Avatar
papajoemrt
I recently had this problem and just found the thread I started on it.
https://www.ford-trucks.com/forums/8...rans-seal.html
Is this where yours is leaking?
Old Sep 16, 2009 | 09:24 PM
dude73's Avatar
dude73
sorry guys i fixed it was just the seal. and yes that looked like my tailshaft only mine ran out of oil. fix it soon.
