Good first time datalogging, my first time was alot worse and it took me a few times to get it right. Like LAyson said, next time do a WOT run, I find starting at 70 mph then punching it helps to prevent the truck from downshifting. The less items you try to datalog the smoother the data.
Thanks for the graph. I followed the instructions quoted above, WOT from 60 to 90. It did downshift though.
That's the hard part - to keep it from downshifting. I try to either roll the throttle a bit more or start at 70 mph. Here's a better graph. The duty cycle on this run does go high. See if you can notice when the CES light goes off.
