Think i have a weak HPOP :( Please confirm...
Well took truck for a drive with the AE and figured i would log the ICP pressure and duty cycle to see the health of my HPOP. Well i am pretty sure i have a very weak one So Opinions needed just to confirm.
I am not sure if there is an exact mph range to test the HPOP or not but i just did a pull WOT from 20-75ish in both Stock and 60E.
Stock the pressure stayed 2600-2800psi and duty cycle was 40ish%
60E was 1900-2100psi and Duty Cyle was 75ish% duty cycle
I didn't have time to do the 100hp tune, but i would assume it would be same as the 60E or worse.
I read that anything under 2600psi is considered weak, so wanted to confirm with you guys that its time for a new upgraded HPOP. The truck hits boost rock solid, but just feels very flat when accelerating if that makes sense. So not sure is the ICP sensor goes bad, would that affect anything or worth replacing as well or is it definitely the HPOP?
I will log some 60-90mph pulls tonite just to confirm. But i am pretty sure the results will be the same or worse. muekster, you have pretty much the mods on your truck( going by the sig anyhow) that i will have, plan to have in near future. How is it all working together? And how is the Stealth HPOP working for you? And big improvement once you put it on ?
on
93f250tn
06-22-2014 05:05 PM
PaysonPSD
29
04-10-2009 02:35 PM
20stroker02
50
04-01-2009 12:28 PM
Tenn01PSD350
71
05-14-2008 10:58 PM
