Hi I have a 2007 Ford F-150 that it is rough at idle and when I put the scanner three codes appeared which are P0316, P0748, P0962. Does anybody know what to do?
P0316.....Crankshaft Position System Variation Not Learned
P0748 ......Pressure Control Solenoid Electrical
P0962....Pressure Control Solenoid "A" Control Circuit Low
On Edit:
Could you double check the xx316 and the xx962? A few of the lists I have does not have the 962 listed as a "local" Ford code, and the 316 was skipped on a few of the lists. It jumped from 315 to 320 on some lists...fyi.
