stalling problems
Old Sep 12, 2009 | 08:48 AM
  #31
MUSKYMAN73's Avatar
MUSKYMAN73
Originally Posted by jboczar
Muskyman, does it starting "knocking" real loud and then stall? If so then it is probably fuel, a good way to tell is once it has stalled without cycling the key, remove the secondary fuel filter housing and see if there is fuel in there. If not, 60 psi is actually excessive fuel pressure per Ford. The spec range is 45-55, I would check for a restriction in the return fuel lines (unlikely) and then replace the regulator, although that shouldn't really cause a stall. Unfortunately the Ford manuals do not list a flow rate for the fuel pump.
Yes it does i checked my level before i started it approx half way up to threads in canister and then checked after it stalled pretty much same hight a touch less.I was supposed to have a mechanic come over lastnight but he could not make it he is suppost to come today try a scan and what not
meapilot
17
May 7, 2015 12:19 AM
triplecreek
May 24, 2011 10:00 PM
dalesgarage_2250
13
Mar 4, 2011 05:36 PM
670johndeere
31
Jun 3, 2006 12:08 AM
gearshift101
Jan 31, 2004 12:01 PM
