Clutch rod boot help
Old Sep 8, 2009 | 08:16 PM
Duke78's Avatar
Duke78
Has anyone ever installed a clutch rod boot? It's the boot that is in the driver floor pan, man it's impossible. Any tips or tricks would be appreciated.
Old Sep 8, 2009 | 09:01 PM
Riderman's Avatar
Riderman
What do mean "impossible"? You disconnect one end of the clutch rod, (the bottom of the rod is easier for me) place the boot over it, and use a small screwdriver and liquid soap as a lube to fit the boot in the hole in the cab floor. It's a tight fit.
Old Sep 8, 2009 | 11:06 PM
Bgasrickshaw's Avatar
Bgasrickshaw
If it's too stiff, you could try heating it up to make it more pliable. Heat gun or maybe really hot water, Avoid open flame
Old Sep 9, 2009 | 06:24 PM
Duke78's Avatar
Duke78
i got the stinking thing in there today. I ended up freezing the boot i'm not sure it it helped but i got it in on the first try today. Thanks for the replies, i appreciate it.
RRranch
Mar 31, 2014 09:50 PM
jimmielee
Sep 12, 2012 08:02 PM
mikecox1
Apr 6, 2009 03:37 PM
beartracks
Sep 17, 2008 02:33 PM
Turgid77
Jan 25, 2006 01:35 PM
