97 explorer 5.0 transplant
Old Sep 8, 2009 | 05:10 PM
jlscheele's Avatar
jlscheele
Guys,
I want to put the longer water pump like out of an earlier 5.0 mustang but it appears the timing chain cover and pump is different. Do you know if there is a Explorer style pump w the longer housing?
Thanks for any help in advance,
John
Old Sep 8, 2009 | 09:16 PM
Conanski's Avatar
Conanski
Doubt it, just put a universal truck pump on it.
Old Sep 8, 2009 | 09:31 PM
jlscheele's Avatar
jlscheele
OK thanks.. Like what kind of truck, year's? Autozone will be confused if I just ask for a universal truck pump.
Thanks,
John
Old Sep 8, 2009 | 09:57 PM
Conanski's Avatar
Conanski
First thing we should establish is the length of the existing pump shaft I guess? Take a pic or measure it and I'll compare it to the truck pumps I have. If thay are the same or close and you want one that's quite a bit longer then you may have to change the pump and water cover to the old mustang style.. which will bolt on no problem.
Old Sep 9, 2009 | 05:51 AM
jlscheele's Avatar
jlscheele
Paul,
Two things I didn't mention are the explorer's wp base and pulley hub are odd. The hub has a threaded stud for the fan and the pulley bolt circle is larger.
I went on rockauto.com were they show pictures of their parts.
All the trucks that still had 5.0's in the 90's had the traditional wp base but the 94, 95 mustang had the explorer base with a normal pulley / fan hub so if anything I would just have run a spacer behind the pulley.
Thanks again,
John
Old Sep 10, 2009 | 09:22 AM
Conanski's Avatar
Conanski
See this thread if you are considerig using a spacer..
https://www.ford-trucks.com/forums/8...lt-system.html
Old Sep 10, 2009 | 04:03 PM
jlscheele's Avatar
jlscheele
Paul,
Good point. I will get the timing chain cover for the older style pump.
Thanks,
John
sykanr0ng
Dec 2, 2015 10:17 PM
jerry_s
Feb 18, 2015 11:07 PM
undertow91
Aug 23, 2012 04:43 PM
88dually
Mar 12, 2012 06:27 AM
rice975.0
Jan 27, 2011 03:32 AM
