I'm not familiar with "Cold Front" but from the cardboard description, I can visualize what it is. Why not just leave the cardboard off and let the fan clutch and thermostat do their jobs?
-Rod
Block the air from coming in in the cold.
That's why they are called cold fronts.
Can get to -50f here and want it to warm up sooner.
Does have a block heater but that ain't enough.
Takes close to 10 min or more to defrost windows in winter.
i would guess in Alaska you need something more. I dont do it with the new F150, but my old F250 had a manual trans and 351 and BIG radiator. IT was slow warming up. I had a piece of galvanized sheetmetal from a house air duct. cut to size with two 2/8 inch holes in the corner. I would slide it up behind the bumper and grill and push up into position. Did not touch the radiator. Put two nylon ties on it for Nov- March each year.
