Sponsored by: Real Truck
No reverse Lights
Old Sep 7, 2009 | 09:35 PM
fallconroe's Avatar
fallconroe
No reverse Lights
I have a 1999 E Super Duty aka MH i dont have any back up lights, Have checked bulb, and wires to back of MH, ever thing looks good, Not sure where to go next. Does it get the signal from the trans. via the Trans range sensor
Old Sep 17, 2009 | 09:54 PM
fallconroe's Avatar
fallconroe
changed the mlp switch
changed the mlp sensor still no reverse lights
is it control by a fuse or relay
Old Mar 1, 2025 | 09:52 AM
Tomstrublue's Avatar
Tomstrublue
5th Gear
On my 2015 350 super duty 6.2 l i found the reverse relay in the eng comp driver side body junction box BJM and tested the relay and fuses but i still have no power to pin 1 of the relay so i am still trying to figure out what is the problem . All this was brought on by adding rigid back up lights to the rear tapping into the reverse lights which draw 1 amp each to the circuit now I’m getting a code p0707 low imput to pcm .
Tomstrublue
Mar 1, 2025 01:55 PM
Bigdaddy77
Nov 3, 2021 06:35 AM
Faceplant409
Mar 15, 2018 07:23 PM
Nubs15
Feb 16, 2018 10:23 AM
CCtaker
Jan 27, 2009 06:55 PM
