Need help id'ing engine.. 351 or 400??
Old Sep 9, 2009 | 10:22 AM
northerndave's Avatar
northerndave
Originally Posted by Bgasrickshaw
Don't pull the oil pan to measure the stroke. Just pull a spark plug, insert something that will fit in the hole (I use a welding rod) and find a reference point ( I use another welding rod layed or taped across some convenient spots where it won't move ). Then mark the upper and lower limits of it's tavel while turning the engine over BY HAND, and that is your stroke.
what he said
something like a brazing rod of a stiff wire like coat hanger wire. find the bottom of the stroke & mark the rod/wire bottomed out on piston & then find the top of stroke & mark it again, measure distance between marks & you've got it.
Old Sep 14, 2009 | 12:59 AM
talktotodd's Avatar
talktotodd
try this
You can tell the engine size by the VIN number. If you tell me you VIN I can figure it for you.
Old Sep 14, 2009 | 01:18 AM
79 f-150 guy's Avatar
79 f-150 guy
the engine was swapped out once.. i'll measure the stroke om it..
RangerHaywood
15
Jul 5, 2010 10:14 PM
cruz76
Mar 26, 2006 05:40 PM
theonlybull
Jan 13, 2003 08:04 PM
Sunfire_Stomper
Sep 4, 2002 07:03 AM
Nathan
13
Apr 18, 2001 02:10 AM
