usually depends on how much machine work is needed...
if cylinder walls spec out you could prolly just do a re ring kit, new bearings, etc...
if it needs bored, crank turned, head redone, it all costs money...no one will be able to tell you how much until you break it all down and the machine shop says what NEEDS to be done.
I spent around 900.00 -1000.00 put they bored it,cam bearings and installed new cam, turned crank,redid the head with new seats valves and complete overhaul set with rings,all the gaskets. Could have got a crate motor cheaper.
