steps to shorten frame
Here's the dimensions...
6' and 8' beds are identical behind the wheels. the difference is between the front of the bed and the wheel well. a shortbed is actually about 6.5 feet and to put the shortbed on I would have to take either 16" or 17" out from the frame between the back of the cab and the front (rear axle) spring mounts.
I was also thinking about maybe leaving enough room for a set of stacks or just leaving the frame long and getting an aluminum fuel tank made to fit between the cab and bed with stacks either side
You cut the frame square with a cut-off wheel in a grinder.
Bevel the cuts inside and out leaving 1/2 the thickness of the frame's metal un beveled.
Butt it together then weld it both sides
Make a square fishplate and camp it centered over the weld inside the frame with points vertical and horizontal as a diamond.
It should sized so that it is about an inch from the top and bottom stringer of the frame channel
Weld it in around it's perimeter
cut a section of the frame you removed to plate over the outer rail bottom
it should be L shaped, extend halfway up the frame channel.
It should extend front and back 1/2 the frame channel's height from the weld then taper at a 45 degree angle to the bottom web.
This plate is bolted in from the sides but NOT into the top or bottom web.
If you do weld it, you weld it in using plug welds. YOU DO NOT PERIMETER WELD THIS PLATE.
Most of the frames strength is in the top and bottom stringer and the stringers width into the web of the frame. drilling or welding into the stringer significantly weakens it but a hole with a bolt nut and 2 washers torqued down in the hole restres 85% of the strenth lost by drilling the hole
Welding in the stringer hardens it making it brittle and crack prone.
It's been done other ways but this is the way to do it according to the automotive engineers for maximum service. It is the approved method for shortening or stretching commercial truck frames which are made from high tensile steel
I agree with almost everything you say.
except... At my shop when shortening a commercial frame we allways move the axle forward rather than chopping out the frame. But welding on the end of the frame for a couple foot extension is fine.
If we were to do a shorten in the middle of the chassis(behind cab) we would do a step notch rather than butt the chassis up flat. Make sure to bevel all areas to be welded.
just my 2 cents...
