This is definitely not a blend door issue. Going down the rad at cruise and the AC will just quit blowing cold air for a few moments. Then it comes back as cold as before. What's up with that?
Is that typical for wear? Sounds like a reasonable solution. Just can't wait to screw with it.
Thanks
Dave is right on the money.
That's very typical on your 3 older trucks. Your 06 is a little bit young for that much wear to happen yet, but it certainly could happen.
