Tranny Pan
Old Sep 6, 2009 | 07:02 AM
BigDog83's Avatar
BigDog83
Tranny Pan
What do you guys think of cutting the trans pan adding (welding) 6" inches to it and putting copper pipe through the bottom of the pan? I am wondering if the pipes in the pan will make the temp to cold in the winter. I'm not sure exactly what I want to do yet so if guys have anything give me a shout. Thanks
Old Sep 6, 2009 | 07:23 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
No, the pipes won't make it too cool in the winter. By the same token they won't make it any cooler in the summer. That seems like a lot of work for zero gain.
If you want to cool the trans get a better cooler. The pan is a terrible place to cool the trans.
Old Sep 6, 2009 | 07:57 AM
BigDog83's Avatar
BigDog83
I did the cooler first. I put a 06 6.0 cooler on which is 3 times bigger than my stock trans cooler. It made a difference but my temps still go to 190 and thats why i was wondering if the pan will work. The trans was rebuilt with a 3 disk torque converter, new seals, shift kit, so there is no slippage. The only other thing I can think of would be the gauge could be wrong
Old Sep 6, 2009 | 09:15 AM
kawa's Avatar
kawa
Greg, is the 190* with a load or are you empty? Either way that's really not that high. I was running the freeways yesterday and my only load was a 1500# aluminum boat and motor and I was at 170* but I am running a 40K stack plate cooler, 3/8 tranny lines and a thermostatic ATF control.
IIRC 220* is acceptable.
Rog
Old Sep 6, 2009 | 06:12 PM
BigDog83's Avatar
BigDog83
Hi, it goes to that temp unloaded, it goes a little bit higher loaded. But the strange thing is before I gotten the new trans cooler, the gauge would go up to 220 or 230. I checked and smelled the trans fiuld and it looks clean since i just had it done and doesn't smell burnt. What is a thermo ATF Control??
Old Sep 6, 2009 | 06:14 PM
Mark Kovalsky
190F is fine. It doesn't need to get any cooler than that.
How do you know there is no slippage? Are you trying tosay you hope there is no slippage?
Old Sep 6, 2009 | 06:24 PM
BigDog83's Avatar
BigDog83
I had my friend who is a mechanic drove it and he said it locks up nice and strong. Plus you can feel when it locks. My old one i had would slip out of second when driving down the road, so i could tell the difference between the old and new. Can a triple disk torque converter create extra heat at all? Thanks for thee input
Old Sep 7, 2009 | 07:54 AM
Mark Kovalsky
The triple disk converter will not create more heat.
Jaime74656
20
Dec 18, 2013 07:21 AM
wicat3
Feb 8, 2012 03:08 PM
beefcake
Oct 5, 2011 09:53 PM
robjs111
1997 - 2003 F150
Apr 1, 2011 08:19 PM
apachetech
Oct 27, 2006 03:29 PM
