Brake light switch wiring
Old Sep 4, 2009 | 10:54 PM
70 Bronco TX's Avatar
70 Bronco TX
I have a tendency to damage or break things when they don't want to dismantle properly. So I'm taking a breath and approaching this slowly. It doesn't look difficult, but I'm trying to learn from past mistakes!
There are two wires going into the "plug" that goes into the brake light switch--one has has broken off and left the metal connector inside the plug. (I snipped the other wire, leaving a couple inches to later reconnect with.)
My questions are: Can I dig that stub out and replace it with something off the shelf? If so, does that little metal stub dig out one way or the other? Or, do I need a new plug--is it all one piece (the plug and wires)?
Pretty silly stuff, but I swear I'll break the little plastic plug if I'm not careful. Thanks--Dan
Old Sep 5, 2009 | 12:10 AM
highboy1975's Avatar
highboy1975
if its like alot of the other ford plugs theres a plastic clip that holds it in there that you can get and replace. could probably hit the pin and release the plug with a small screwdriver or some kind of small rod.
Old Sep 5, 2009 | 05:02 PM
70 Bronco TX
Thanks, HB75, I tried a bit and just figured I'd check out the parts store in the morning. They didn't have a new plug so I tried something else...I shoved in another connector and it is holding tight. All back together and working fine!
HEpTJJ
Jul 22, 2014 10:06 PM
One Sock
Feb 13, 2011 05:06 PM
blighty
Electrical Systems/Wiring
Jan 5, 2008 08:10 PM
Critterhunter
1983 - 2012 Ranger & B-Series
Feb 1, 2006 08:01 PM
fiatman71
Jan 27, 2006 02:05 PM
