Shocks
Old Sep 6, 2009 | 05:14 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
I installed Gabriel gas shocks on mine 11 years ago and haven't had any issues.
Tim
Old Sep 6, 2009 | 07:54 PM
tivoklr's Avatar
tivoklr
Just ordered Monroe Gas Magnums for all four corners. Less than 100 bucks shipped.
Should be a significant improvement. With the current set I have horrible nose diving at highway speeds while changing lanes. The PO installed new ball joints and didn't get an alignment, so that is part of the problem too but there is no dampening right now...
Old Sep 6, 2009 | 08:46 PM
RustyGreen's Avatar
RustyGreen
I recently put new shocks on my 150 and went with The mid-grade "better" option Of the Gabriel shocks from Auto Zone. Had a guy at work put them on for me at a bargain of a price. It rides better than before but I am still getting used to how rough it still seems to be. I Have the twin or split beam axle in the front and wonder if that makes for a rougher ride.
Old Sep 6, 2009 | 10:05 PM
lopitt85's Avatar
lopitt85
Originally Posted by BigSix1
Impossible.
Unless...did you get the Autozone "Anti-gravity Upgrade Shocks???"
Yeah I did, and they came with a free teleportation horn. pretty nice combo huh?
Old Sep 7, 2009 | 03:49 AM
TexasGuy001's Avatar
TexasGuy001
Actually, the Gas pressurized shocks that push out do make the truck sit higher. Its not by much though.
My truck sits about 1/8 to 1/4 inch higher with the RSX than with the 5000. I measured it before and after.
The 5000 you can move in and out. The RSX and other pressurized shocks thats not so easy to do since they push out.
So, I can see how with new gas shocks versus worn out shocks that the bed won't sag as much when additional weight is added.
The load capacity of the truck is not increased though. It just handles it better.
Old Sep 7, 2009 | 09:57 AM
Otto Square's Avatar
Otto Square
I agree with you, but it's not much. 1/16th to 1/8th inch is more likely. No way 1/4 inch.
Eitherway, it's not going to make a noticable difference when loaded
Old Sep 7, 2009 | 08:40 PM
lopitt85's Avatar
lopitt85
I can only tell you what difference I saw. Before I changed the shocks, if I stood on the rear bumper, the back end would sag noticably. And I could bounce the truck like a basketball. I put on the new shocks (Apprx. $30 Gabriel Ultras) and when I stand on the bumper it doesn't drop nearly as much as it did before...and I can't bounce it like I could before either.
Old Sep 7, 2009 | 09:51 PM
Diesel_Brad's Avatar
Diesel_Brad
Like stated before. Shocks had(have) nothing to do w ride height or weight carrying capacity
Old Sep 7, 2009 | 10:15 PM
Ford4x4-JD70AB's Avatar
Ford4x4-JD70AB
I have a set of Skyjacker nitro shocks on my f150 and like them a lot. I had a set of rough country shocks that came with my lift kit and they were ok for about 20k miles, then they were about worthless. I wouldnt hesitate to go with the skyjackers again.
hulleywoodworking
Feb 12, 2020 09:25 AM
Wheelman55
Nov 4, 2016 05:48 PM
mjlewis
2004 - 2008 F150
Sep 15, 2015 09:50 PM
berick
Nov 24, 2008 01:40 PM
TexasPioneer
May 5, 2004 11:54 PM
