I was needing to replace the drivers side front door latch on a 99 EB expedition. I was wondering if anyone had a diagram or instructions on how to get all the rods loose and in what order. Any help would be greatly appreciated. Does the rivet have to be drilled out of the actuator to get everything loose. Thanks
It will open from the inside, but not the outside. It all started when the rod from the tumbler to the latch came off...rolled the window down and it bent that rod, and messed up the latch. Ive had the door panels off and the latch is not working like the "good " passenger side is. i got the replacement parts from a salvage yard...just needing a little installition instruction.
REMOVAL
Remove the front inside door handle. NOTE : The front door window glass must be completely up.
Remove the watershield.
Remove the rear glass channel bolt and position the glass channel aside.
Disconnect the rods from the door latch.
Unclip the locking clip.
Disconnect the door lock rod.
Position the front door latch aside.
Remove and discard the screws.
Position the latch aside.
Disconnect the electrical connectors and remove the latch.
INSTALLATION
To install, reverse the removal procedure.
If necessary, use Multi-Purpose Grease Spray F5AZ-19G209-AA or equivalent meeting Ford specification ESR-M1C159-A to lubricate the latches.
NOTE : Install the front door latch screw in the small opening first, followed by the large opening.
