barn door latch
Old Jul 21, 2014 | 10:00 AM
ithaca1230's Avatar
ithaca1230
barn door latch
Anyone have a broplem with the rear door latching?the glass hatch closes ok it is just the barn door that wont latch. Is there a fix or do I have to replace the lock mechanism. Thanks
Old Jul 21, 2014 | 11:53 AM
Stewart_H's Avatar
Stewart_H
First I've heard of this problem.
Have you tried cleaning (copious amounts of brake clean or something similar) and then a spray lubricant?
Stewart
Old Jul 21, 2014 | 02:06 PM
ithaca1230's Avatar
ithaca1230
Yes I have cleaned and lubed. It is the second door. I tried to latch the lock with a screwdriver but it wont hold shut. Was hoping someone else might have a simple fix.
Old Jul 21, 2014 | 02:20 PM
LivingLarge's Avatar
LivingLarge
I'm sorry to say, you may finally have to get rid of the EX. Never heard of this issue.
Old Jul 21, 2014 | 02:49 PM
ithaca1230's Avatar
ithaca1230
Darn it! well I'll have to start all over. It actually stays closed without the door light on after you close the glass hatch.
Old Jul 22, 2014 | 04:07 PM
PoPs 03DEX's Avatar
PoPs 03DEX
Rear barn doors
Is this the left (drivers side) or right Passenger side that is not latching?
I had to adjust the drivers side D ring that comes up from the floor because it was out of alignment (loose).
Old Jul 23, 2014 | 07:45 AM
ithaca1230's Avatar
ithaca1230
It is the passenger side. The second door to close before you shut the hatch. I tried to get the mechanism to lock with a screwdriver but no go.
Old Jul 23, 2014 | 10:13 PM
PoPs 03DEX's Avatar
PoPs 03DEX
Is the handle loose?
I will try to send you a photo of what I see inside as I have the cover off.
It may be a spring
Old Jul 24, 2014 | 07:09 AM
ithaca1230's Avatar
ithaca1230
Thanks that would be great. I found a guy that has a wreaked one and was gonna buy the rear doors just for the lock.
Old Jul 24, 2014 | 01:56 PM
PoPs 03DEX's Avatar
PoPs 03DEX
Inside Latch
Top Handle Release
Connecting Bar, Check the Yellow/White clip
Latch, Check the spring
Old Jul 24, 2014 | 02:04 PM
ithaca1230's Avatar
ithaca1230
Thanks gonna mess with it this weekend the pics are good help.
Old Jun 6, 2019 | 08:22 PM
kcdude's Avatar
kcdude
No fix?
I'm having this same issue what did you do? Buy new latch? Is it spring?
Old Jun 7, 2019 | 04:14 PM
Squirrel13's Avatar
Squirrel13
For anyone that is gonna work on the door locks etc be prepared to break the brittle clip holding the locking rod. So you dont have to struggle thru the parts catalog. This is what you you are looking for.
smoke n tires
Oct 13, 2011 05:19 AM
So-Cal
Dec 23, 2008 06:12 PM
49willard
Jan 25, 2008 09:08 PM
OddManOut
1983 - 2012 Ranger & B-Series
Dec 6, 2007 05:12 PM
