electric cooling fan
Old Sep 4, 2009 | 05:39 PM
mickpowell1967's Avatar
mickpowell1967
could someone tell me at what temp does the electric engine fan comes on
Old Sep 4, 2009 | 09:25 PM
bismic's Avatar
bismic
Engine temperature is not the only parameter that the PCM monitors to determine cooling fan operation. This is the reason that you will see some variation in engine temperature as it correlates to fan operation. The operation/description of the FSS (Fan Speed Sensor) from the PC/ED manual has a fairly good explanation as to how the system "thinks". This is not your traditional engine hits temp X and the fan clutch locks up. The fan speed sensor is a Hall-Effect sensor integral to the vistronic drive fan (VDF). The powertrain control module (PCM) will monitor the sensor input and control the VDF speed based upon engine coolant temperature (ECT), transmission fluid temperature (TFT) and intake air temperature (IAT) requirements. When an increase in fan speed for vehicle cooling is requested, the PCM will monitor the FSS signal and output the required pulse width modulated (PWM) signal to a fluid port valve within the VDF.
Old Sep 6, 2009 | 09:33 AM
mickpowell1967
thanks for the reply,i have only owned the truck for a month engine temp runs 188 on days that are below 90f and 190 to 193 above 90f with out a load never really put a load on yet i just never heard it kick in
4 rings
Oct 18, 2013 11:53 AM
RUBICON
2009 - 2014 F150
38
Nov 23, 2009 08:47 AM
dhag911
18
Jan 2, 2008 09:27 PM
The Phenom
1997 - 2003 F150
Nov 30, 2003 07:59 PM
georgemu
Aerostar
Mar 12, 2001 11:58 AM
