'97 Explorer v8 allwheeldrive
Old Sep 4, 2009 | 09:58 AM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Hi all, I usually linger in the diesel forum but was wondering if anyone here has tinkered with the electrics involving the transfer case. Specifically, putting in a manual overide to put in 4x4? Anyone done this?
Thanks, Bill
Old Sep 4, 2009 | 12:30 PM
shorod's Avatar
shorod
So does your Explorer have AWD currently, or is it the Auto 4WD? If the auto system, yes, I've read of folks wiring in mods to that. If it's AWD, you have a center differential and will not be able to get true 4WD without changing out the transfer case. I'm not sure what else would be involved.
-Rod
Old Sep 4, 2009 | 11:32 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Yes it is awd. I hear the v8's only came this way.
Old Sep 5, 2009 | 07:48 AM
shorod's Avatar
shorod
I was under that impression too, but I've heard of some having V8 with 2WD. That sounds like fun, but I can't say that I've ever seen one.
If you have the AWD transfer case, there's no way to convert it to 4WD other than to swap out the transfer case and probably other pieces as well.
-Rod
Old Sep 5, 2009 | 11:15 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Mmm, I wonder, I also own a '93 explorer that's becoming a rusting hulk in the driveway. It might be time to cannibalize it if the transfer case would work.
Old Sep 6, 2009 | 09:59 PM
460's Avatar
460
I don't think it will work... different splines on the output shaft. A t-case from an F150 will be needed.
Old Sep 6, 2009 | 11:10 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
I may scrap the idea then, I heard it doesn't make much difference in gas mileage anyway.
mudlite
2004 - 2008 F150
Nov 9, 2009 09:56 AM
soundwave
2009 - 2014 F150
20
May 28, 2009 11:54 AM
dpj
6.4L Power Stroke Diesel
Nov 30, 2007 05:32 PM
02fidyCrew
Jan 4, 2005 03:58 PM
F2504x4
Ohio Chapter
42
Nov 17, 2004 09:49 PM
