Backfire through Carburetor
Old Sep 3, 2009 | 04:56 PM
ReyTs66Ford's Avatar
ReyTs66Ford
Hello All, new to the forum and have read alot of good posts. I have a 66 Ford F100 with a 390 V8 engine from a '68. I have a new edelbrock carburetor 650 scfm and a custom exhaust.
When I drive it around at normal speeds the exhaust has some backfire. I am assuming I might have and exhaust leak somewhere. but more than likely the exhaust and intake backfiring are related.
When I really step on it, I get backfire through the carburetor. I had an engine compression check and the results were good. Nothing wrong with the valves. my vacuum is a little lower than normal I run about 15". I have changed the vacuum lines but it also has not improved. I have been told my truck does run lean so maybe I need to adjust the secondaries on the carburetor to get more fuel in the engine when I really accelerate. Any comments or suggestions?
I am fairly new to these trucks and I would consider myself a novice mechanic. But I can get things done when I have a plan. Just want to get some comments before I start messing with it. She runs okay now but If I could fix the backfiring she would run like a champ. Thank you.
Old Sep 3, 2009 | 05:53 PM
Bill W's Avatar
Bill W
Welcome to FTE. do you have a stock Distributor or aftermarket? Backfiring through the carb was a timming issue for my truck.
Old Sep 3, 2009 | 09:56 PM
gangstakr's Avatar
gangstakr
It definately sounds like timing.
areoseek
21
Dec 3, 2015 12:21 PM
10129
Feb 9, 2015 03:39 AM
JeepScrambler
Oct 24, 2014 10:18 AM
gordo2
20
Jul 15, 2014 05:28 PM
ColtonMullis
Jan 20, 2014 03:53 PM
