351 loading up and backfiring?
Old Feb 8, 2015 | 01:16 PM
10129's Avatar
10129
Ok, I know "loading up" is probably not the right term but here's what it's doing. I just rebuild the carb but it was doing this before too. WHen you get it cranked it runs but kind of rough and it seems like it "loads up" meaning you have to keep giving it more gas to hold the same RPM. It sounds like something is bogging the motor down or it is straining against something. Then after a while it will start to backfire. It will occasionally backfire really loudly and sometimes seems to puff out the carb instead of the tailpipe right as it stops running. It has a new ignition module and I checked the timing and it appears to be spot on. Also, hooking up the vacuum advance seems to make it backfire worse and quicker. Any ideas?
Thanks,
Old Feb 8, 2015 | 01:21 PM
HIO Silver's Avatar
HIO Silver
Look for a vacuum leak... the smallest cracked hose(s) can make the engine go cattywampus...
David7.3's Avatar
David7.3
Well sounds like a power valve went bad, every time you get a backfire you risk blowing the power valve, and that means fuel is dumping in. with a flashlight look at either venturie, and see if fuel drips from them. if so you blew the power valve. What carb is on the engine?
Old Feb 8, 2015 | 05:35 PM
10129's Avatar
10129
Mc2150. It backfired before the rebuild too. Has a brand her power valve.
Old Feb 9, 2015 | 03:39 AM
10129's Avatar
10129
So does the fact that it gets noticeably worse when the vacuum advance in hooked up point to a bad distributor? I'm working on selling it so I'm trying to avoid replacing any more stuff then I have to.
bhain
18
Oct 15, 2018 12:37 PM
reflections
May 8, 2009 10:18 AM
ramarado
17
Jun 29, 2008 11:58 AM
71LTD390
Sep 5, 2004 10:40 AM
jamorg2
Oct 17, 2003 12:17 PM
