Fasteners
Old Sep 2, 2009 | 11:40 PM
Broomfieldbum's Avatar
Broomfieldbum
Fasteners
I am looking for the body part bolt clips. My truck is missing most of the bolts for the front clip, and getting the bolts is not hard. I would like to find replacement clips so that I don't have to go through the hassle of finding a way to grab the spinning nut so I can remove the body part. Any help would be appreciated.
Old Sep 3, 2009 | 01:10 AM
LOWLID's Avatar
LOWLID
Got mine from Ebay pretty reasonable.
Old Sep 3, 2009 | 03:39 AM
daveengelson's Avatar
daveengelson
May try a local quality hardware store. Seem to recall Home Depot carries a limited selection, seems they were in another location than the nuts and bolts section of the hardware department. Posting links to couple of possible sources. Found Restoration Specialties carried many of the hard to find fasteners I needed to reassemble the 65; fender bolts, U and J clips, tube nuts, castle nut; secures grille support, etc.. Not familiar with the second link, believe another member posted the link and I bookmarked for reference.
http://www.restorationspecialties.com/
http://www.northlandfasteners.com/catalog/db6.html
Old Sep 3, 2009 | 04:16 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Try an Automotive Paint Supply Store where body shops buy hardware, paint, and etc.
The longer the store has been in business, the better chance you have of finding the correct clips.
Old Sep 3, 2009 | 07:31 AM
BobbyFord's Avatar
BobbyFord
Try Auveco...
http://www.auveco.com/product/index.html
Old Sep 3, 2009 | 09:45 AM
jared66's Avatar
jared66
I got mine from a local company that just sells bolts and fasteners. It was called "Double D Bolt." I'm sure you would have something like that in your area.
Old Sep 3, 2009 | 01:18 PM
NumberDummy
Originally Posted by instig8r63
They don't have them. I looked up the Ford part numbers, couldn't find any at obsolete parts vendors, Ford Dealers.
Then I used my Auveco catalog's cross reference = Ford to Auveco part numbers. Nada.
I've known the SoCal Auveco reps (father & son) since 1964, have their current catalog.
Old Sep 3, 2009 | 04:08 PM
tbm3fan's Avatar
tbm3fan
Take a look at this link and you will see many J and U-clips that can possibly be used just by looking for the correct size which is 5/16-18 I believe. At least you can see different designs...
http://www.amkproducts.com/Catalog_PDF/56-73.pdf
Old Sep 3, 2009 | 04:50 PM
drof46's Avatar
drof46
I took out my inside cab gas tank and reused the three holding it on the front clip. You may look for other member who have removed the inside gas tank and get them to pull the clips out for you.
jays92
Aug 26, 2013 01:16 AM
95stepside
Sep 13, 2012 07:47 PM
Christopher2
Sep 19, 2004 02:29 PM
oldhalftons
Mar 19, 2004 11:55 PM
