Think I have a oil pan gasket leak
So I'm down in Louisville at an Days Inn tonight and just noticed i have an oil leak. Whipped out the mag light and determined the leak is coming from the oil pan gasket just below the crankcase pully for the serpentne belt. I will have to just check the oil periodically cause I wont be home until next Monday.
My question is this, and i pray the answer is yes...Can I replace this gasket without pulling the motor?
It may be a front crank seal, easier to fix than a pan gasket.
If it turns out to be a pan gasket.....you either pull the engine or cut the cross member to get the oil pan off. Here's a link to the cross member I cut out:
https://www.ford-trucks.com/forums/7...il-pan-qs.html
Factory service manual online:
http://www.thedieselstop.com/faq/949...an/stjmain.htm
thanks Jim for the links. For now, I'm going to just make sure I keep enough oil in it until I can get home. It's been an adventurious trip so far...noticed oil leak... and my vaccum pump went out today - almost making me mow over a car when my brakes suddenly got rock hard.
I still dont have it back together. I couldn't use my old pulley as it's worn out. So I have to wait until tomorrow morning to get one from the local dealership.
Yep I'm officailly stranded away from home. Hopefully i'll be good to go tomorrow morning though...
Then there is the issue of installing the pan w/o much clearance....you gotta work fast & clean to get the pan to seal up good. The sealant doesn't like the dripping oil before it's cured.
If you email it to me I will host it for you.
mustangmatt96gt@comcast.net
the easiest way is to upload the picture to an online hosting site, such as flickr or photobucket and then paste the image code in there... but ill host if for you.
Loks like i need to get a photobucket going.
