Sponsored by: Real Truck
ABS light on and off
Old Sep 2, 2009 | 03:27 PM
97F250XLT's Avatar
97F250XLT
05 SD V10 Auto 4.30 cruise control was working and ABS light came on. Shut truck off light stayed on hit a rough street and light went out. Driving home today light came back on then on cruise and hit rough highway nad tach and speedometer went up and down. reset cruise and it worked fine again. what speed sensor is used to control the cruise control in this truck, a front wheel or the rear differential sensor? Is there a ohm test to do on this sensor or just replace the sensor?
Old Sep 2, 2009 | 03:38 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Before you do anything else, check level of brake fluid. If brakes are getting worn, it's normal for the fluid to go low.... may be time for new brake pads.
TallTexan
Apr 20, 2015 07:44 PM
run6.0run
Feb 28, 2012 04:32 PM
67nukeford
Aug 19, 2011 09:17 AM
Stevie Ray
Oct 26, 2010 10:41 AM
Orion_70
Oct 6, 2010 11:47 AM
