Wheel bearing stud replacement?
Old Sep 1, 2009 | 10:56 PM
'86_150's Avatar
'86_150
Hey guys,
Im replacing my wheel bearing on my drivers side and i was wondering what torque those studs on the needle bearing side need to be at or if they will torque themselves when i torque them to the truck. any help would be appreciated thanks a ton!
Old Sep 1, 2009 | 11:13 PM
SpringerPop's Avatar
SpringerPop
Just make sure they're in as far as they'll go, and they'll be fine when you torque the nuts.
LocTite on them couldn't hurt, though...
Pop
Old Sep 1, 2009 | 11:27 PM
Tenn01PSD350's Avatar
Tenn01PSD350
So you are replacing the hub? Do what Pop said and put some loctite on run them in as far as you can.
Old Sep 1, 2009 | 11:41 PM
'86_150's Avatar
'86_150
Yea im replacing the hub but the studs dont come already screwed in. Thanks guys appreciate the replies ill just loctite em and tighten em as good as possible and put em on the truck thanks appreciate it.
Old Sep 1, 2009 | 11:50 PM
Tenn01PSD350
Yeah, they won't come out. Use the nuts from the original install and tighten them down. Good to go.
Old Sep 2, 2009 | 09:04 AM
brian42's Avatar
brian42
Veteran: Navy
Torque spec for the hub-to-knuckle nuts is 133 lb-ft.
Old Sep 2, 2009 | 11:07 AM
'86_150's Avatar
'86_150
thanks guys appreciate it, will i need a alignment after replacing this thing? I didnt see any spots for adjustment but i just wanna be sure.
Old Sep 2, 2009 | 11:09 AM
Tenn01PSD350
If you did not remove the knuckle, no worries. Nothing will change. If you do remove the knuckle you need to pay attention to the shim/plate and reassemble the way it came off.
Old Sep 2, 2009 | 12:26 PM
'86_150's Avatar
'86_150
Alright thanks Mike.
