glowplugs
Old Sep 1, 2009 | 12:08 PM
mh5500's Avatar
mh5500
glowplugs
How do you change glowplugs and where is a good place to buy them for 2003 6.0?
Old Sep 1, 2009 | 12:39 PM
cartmanea's Avatar
cartmanea
I think dieselfiltersonline.com has a good price on them, not sure if its the best though. Are you replacing them all or do you have just a few out? Did you get engine codes that they were out or just symptoms?
Old Sep 1, 2009 | 12:49 PM
mh5500's Avatar
mh5500
No codes. I don't know whats going on. When I first start the truck in the morning it starts and shuts off once, twice, sometimes three times before it stays running. Then it will start ok the rest of the day.
Old Sep 1, 2009 | 12:50 PM
rocky1074's Avatar
rocky1074
Dieselfiltersonline does have them. They are 9.50 each for an 2003 6.0.... Below is the link for them..
http://www.dieselfiltersonline.com/Z...Plug-Zd12.aspx
Old Sep 1, 2009 | 12:59 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Maybe NOT glows.... have you had your codes read? Yes, you CAN have codes without your CEL coming on! Could also be EGR system....or something else altogether.
Old Sep 1, 2009 | 01:00 PM
brickie's Avatar
brickie
Are you getting clouds of white smoke?
Old Sep 1, 2009 | 01:05 PM
mh5500's Avatar
mh5500
No smoke. I have my EGR unplugged and JB Weld shut.
Old Sep 1, 2009 | 01:10 PM
brickie's Avatar
brickie
It is not your glow plugs,it is something else.Find a code reader.
Old Sep 1, 2009 | 01:11 PM
cartmanea's Avatar
cartmanea
If no smoke its not glowplugs; they are a rare failure on the 6.0L. Also, I'm not sure if I would put JB Weld inside the intake manifold. Its good stuff, but if some comes loose it could wipe out some valves.
Old Sep 1, 2009 | 01:13 PM
brickie's Avatar
brickie
X2 on that ^
Old Sep 1, 2009 | 02:17 PM
npccpartsman's Avatar
npccpartsman
I'm voting for the FICM. Does it shutdown almost immediately when you start it and it starts right back up?
Old Sep 1, 2009 | 02:21 PM
mh5500's Avatar
mh5500
It starts and kinda revs up then shuts off
Old Sep 1, 2009 | 02:23 PM
npccpartsman
Mine did that for 3 months before it threw the FICM code. It could also cause you injector problems.
Old Sep 1, 2009 | 02:34 PM
mh5500's Avatar
mh5500
If I take it to Autozone and hook it up to their code reader would that tell me anything?
Old Sep 1, 2009 | 02:39 PM
npccpartsman
It's very possible their code reader will, but I don't know what kind of capability it has. When you said no codes was that from a scan or from no check engine light? If code P0611 comes up then you should get a FICM on the way as it could fail at ANY moment. Not trying to scare you, but you could be cruising down the interstate and it fail without warning. Then you might need a LOT of toilet paper.
