Coolant leak from inside of fan pulley?
There is a weep hole in the shaft housing. When it starts leaking like that it means the seal is wasted, maybe the bearings too. Grab the fan and see if it wiggles up/down, side to side. If it does, then pay close attention to your fan clutch as well. It could be worn and vibrating which will shorten the life of your next water pump.
There is a big nut that you need to back off in order to get the fan off the six. Since the fan motion tightens the bolt, it can be stuck on there pretty good. You definitely need the special tool.
Not to scare you, but the last time I did this, I could not budge the nut even with the tool. I just about busted both arms trying to get it off, and I'm a pretty strong guy. I ended up putting a big crescent wrench on the nut, securing the rented tool against something like the radiator support, and hooking an engine lift into the end of the crescent. I lifted the front of the truck up a few inches before it popped loose. The next waterpump that had to get fixed went to the shop.
The one in Auburn is kinda close, but we're upwind of it so things are pretty clear here. We live in the burbs and are pretty well insulated from the fires themselves, but last summer there were a few days I didn't even dare to go outside there was so much smoke in the air. So far it's been good this year.
Well, I have a crescent wrench that will fit around the fan nut, and a hopeful way of holding the fan pulley, but first I need to remove whatever that plate is that the fan is attached to. Problem is, there is some wierd coil thingy in the way of getting that off. They didn't mention that in the autozone guide, which isn't very detailed:
this is the exact sort of unforeseen BS I always run into. Nothing is ever easy.
Drain the cooling system.
Disconnect the lower radiator hose from the water pump.
Remove the drive belt, fan, fan spacer, fan shroud, if so equipped and water pump pulley.
Remove the alternator pivot arm from the pump.
Disconnect the heater hose at the water pump.
Remove the water pump.
you do not remove the coil thingy.
the tool is to hold the fan pulley.
do yourself a favor and rent one from your auto parts store.
disconnect the fan shroud and put some cardboard between the radiator and the fan.
you will not like it when you mess up the radiator if you do not do this.
read a whole bunch of posts on this before you start on this job.
